Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
Posted on Aug 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know the spark plug gap for Homelite 25cc Model UT-20779
  • Anonymous Mar 24, 2014
    Need plug gap setting for model ry80030
Daniel
Level 2:
Novelist:
  • Expert 123 Answers
  • Posted on Aug 04, 2011
Daniel
Expert
Level 2:
Novelist:
Answers
123
Questions
Helped
107378
Points
198
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
What is the spark plug gap for a homelite 2700psi pressure washer with champion eco 322
The recommended spark plug gap for a Homelite 2700 PSI pressure washer with a Champion Eco 322 spark plug is 0.030 inches.
but in my opinion, It's always best to consult the owner's manual or contact the manufacturer for the most accurate and up-to-date information regarding the proper spark plug gap for your specific pressure washer model.
good luck
Homelite chainsaw ut 10516 won't start have replaced all electrical parts still no spark why?
Incorrect gap on ignition coil? On/off switch stuck in closed position and grounding out spark?
1helpful
Spark plug gap for homelite textron ut 10080c chain saw
Hi idone8...
Set your gap using a round feeler gauge to .28 to .32
Please take time to rate me
Sep 08, 2011 • Garden
3answers
1helpful
Homelite ut 10695 spark plug gap, gas oil ratio?
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
1helpful
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
3helpful
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
