SOURCE: washing machine
sounds like a pump problem. see if theres a broken belt going to the pump. if its a direct drive unit then the clutch solinoid could be defective or the timer as well. What you need to do is if its a direct drive is measure the voltage on the solinoid or switch wehn its supose to dran if its there then the switch or solinoid is bad. If its not there then most likly the timer but I would need to see the wiring chart to be sure. good luck PS the wiring chart is inside on the back or on one of the sides in most washers and dryers.
SOURCE: Indesit W123s
Bearing Kits are available from here: http://www.ransomspares.co.uk/indesit-washing-machine-spares.html You need part number 1605077
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
