SOURCE: Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
SOURCE: I have a Chefmate Mini Fridge - BC-50A that does
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
SOURCE: NEED FAN MOTOR FOR CHEFMATE REFRIGERATOR MODEL#
remove motor and use the numbers on motor for replacement most appliance, hvac,and electrical supply stores even online carry replacement
SOURCE: will not cool light does not
unplug, take the back cover off.
Look at the circuit board.
at the top right of the board there is a fuse.
if it is blown, the frige is dead.
you will probily find that there is a brown burn mark
on the upper left side of the circuit board under an aluminum
heat sink. that electronic part probily overheated and blew up.
unless your electronics skils are up to it throw the frige away.
but if you are up to it unsolder it, bring it to frys electronics, and
get a new one. Good luck.
