I have a PCI card with USB and Firewire ports, external and internal. For the internal Firewire (1394) connections, it has an 8 pin header (individual pins) and the standard large firewire connection. I need the definitions of the individual pins so I can connect my front Firewire connector.
Http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
It is a PCI card - not connected directly to the motherboard.
You can see the 8 pins that are connected to the same lines as the regular firewire connection, but I have no documentation on what pin goes to what for the Firewire, and the 8 pin does not seem standard (I have seen some 10 pin header diagrams, but not 8).
ok fair enough.... any writting/labels on the pci card would be helpful
motherboard name and model ?
