Miller Trailblazer 302 Welder Generator 907217 907216 Logo
Posted on Aug 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i strike a arc the engine wont kick up i have to to turn the switch torunfull throttle and then turn the switch and wait for the engine to come back down when im done with my weld thanks
Anonymous
Level 3:
Genius:
  • Master 1,212 Answers
  • Posted on Jan 07, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1212
Questions
0
Helped
469533
Points
2874
Check the coil and connections to the 24 volt contactor.
My sa 200 will not rev up when trying to strike an arc it will rev up when you use the grinder
Magnetic reed switch near output is probably bad. Look for coil behind front panel, there is a small glass tube inside, with 2 small wires.
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
How to relearn throttle body on a Lexus is250
Pedal Relearn Procedure
Accerlerator Pedal Released Postion Learning is and operation to learnicon1.png the full released postions of the accerlerator pedal by monitoring the accelerator pedal sensor output signal. It must be performed each time harness connector of accelearator pedal postion sensor or ECM is disconnected.
1. Make Sure the acceleartor Pedal is fully released
2. Turn Ignition switchON and wait at least 2 Seconds.
3. Turn ignition switchOFF and wait at least 10 Seconds
4. Turn Ignition switchON and wait at least 2 seconds.
5. Turn Ignition switchoff and wait at least 10 seconds
Throttle Valve Relearn
Throttle ValveClosed Postion Learningicon1.png is to learn the fully closed postion of the throttle valveby monitoring the throttle position sensor output signal. It must be performed each time harness of
electric throttle control actuator or ECM is disconnect.
1.Make sure accelerator pedal is fully released.
2. Turn ignition ON
3. Turn igntion switch OFF and wait at least 10 seconds. Make sure that the throttle valvemoves during the 10 seconds by confrming the operating sound.
(You can hear the TB sound when you have key on and shifter in first gear and step on the gas. So you know what you listening for.)
Idle Air Volume Relearn Procedure
The Following Condtions Must be met in order for procedure to Work.
Battery Voltage :More than 12.9 volts at idle
Engine Coolant Temp 158-203 degrees Farenhiet
Electric Load Switch OFF i.e Air Condition, headlamps , rear defogger
Steering Wheel: Neutral Postion (Straight Ahead)
PNP Switch: OFF (Park Neutral Switch i.e. Clutch Switch...pretty sure)
1. Perform ACCERLEARATOR PEDAL RELEASED POSTIONS LEARNING
2. Perform THROTTLE VALVECLOSED POSITION LEARNING
3. Start engine and warm it up to operation temperature
4. Turn igniton switch OFF and wait at least 10 seconds
5. Confirm Gas Pedalif fully realeased, then turn igniton switch ON and wait 3 seconds
6. Fully step on and release gas pedal5 time within 5 seconds
8. Wait 7 seconds and fully step on gas and stay on until MIL stops blinking and is steady.
9. Fully release the Gas pedalwithin 3 seconds after the MIL has turned ON steady.
10. Start engine imediatly and let idle. Wait 20 seconds.
1helpful
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
2answers
Slow throttle reponse to load
Your welder is too much for the generator you are using. Usually you need a fairly big generator for welding so it doesn't overload so easily.
What electronic part is damaged?
Does the electrode stick to the metal? In which case your problem is with the elctrode or your method of striking the arc.
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
6helpful
3answers
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
1helpful
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Top Miller Welding Tools Experts
Sean Wright
Sean Wright
john h
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
