Click start click on my computer you should see your usb drive
right click on your photos then select delete
or select format this will remove all data on this drive
Check to see if you have the lock switch on, this is a small slider on the side of the card. If it's enabled you will need to slide it to unlock and place it back into the computer/camera. You will then be able to delete the contents of the card.
