Hopefully, if you were to press the menu button and somewhere on the screen will be DTV. Select DTV and then you can run search again. Hope that makes sense.
These are the steps to reset the DTV features and unfreeze your TV:
Ensure the tv is in analogue mode, not dtv and turn it off.
With the remote:
press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
Turn the tv back on & it'll re tune all its channels. DTV should be working again.
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
when booting immediately after the first chime before the grey screen hold down keys (apple,option,p,r) allow the computer to restart if it still goes to that blank screen restart again and this time hold down only the (option) key or maybe (option,s) on that model try option key first then select the main start up disk from the menu and click the arrow underneath
1) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
When you turned off the Wii, did the light turn red or amber? If you haven't done this already, hold the power button until it shuts off, and the light is red. Power it back up and try your remote again.
Phil..
to reset: Info>Menu>Mute>Power Button
make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings.
if you just want to reset freeview..
0 0 0 0
then press the colour buttons in sequence..
im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
