SOURCE: treadmill stopped and lights started blinking and
Sounds like the safety tether is not making contact with the switch make sure it firmly in place. Sometimes these switches will mis-align then the upper console would have to be removed usually held on by phillips screws and can be seen out of place
SOURCE: I have a horizon fitness
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
