This machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
to add to my earlier post the new boards are up-graded from the original just so that that problem will not happen again.
Hot summer day is about to,Open the wardrobe is not yet found love after
another the right clothes? So, also waiting for? Immediate action bar!
Welcome to {http://www.famalegoods.com } sure you will find what you need.
Moreover, the company has a good reputation, product quality standards,
at reasonable prices. Over the years, has been well received by overseas
friends for their support. Therefore, please rest assured purchase.
++++http://www.famalegoods.com ++++++++++
Best online store
Best quality, Best reputation , Best services
---**** NHL Jersey Woman $ 40 ---**** NFL Jersey $ 35
---**** NBA Jersey $ 34 ---**** MLB Jersey $ 35
---**** Jordan Six Ring_m $36 ---**** Air Yeezy_m $ 45
---**** T-Shirt_m $ 25 ---**** Jacket_m $ 36
---**** Hoody_m $ 50 ---**** Manicure Set $ 20
---**** handbag $37 ---**** ugg boot $43 ---****
---**** sunglass $16 ---**** bult $17 ---****
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
Select the wash cycle and press the "Start" button.
If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
