My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
Refill fuel tank with an 2-cycle Oli/gas mixture.
40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
Remove the spark plug.
Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
Remove the pull cord assembly (4-bolts)
This reviled the crank shaft-Pull cord bracket
I use a large monkey wrench to turn the shaft (CW) Clock-wise.
Complete approximate 20 revolutions.
Reassemble, but don't install the spark plug yet.
Complete approximate 20 more revolutions
by pulling the pull cord.
Use q-tips to swab the top of the piston, as much as possible.
Install the spark-plug and crank, it will smoke for amount 7-10 minutes
SOURCE: What type of oil do I need to mix with the gas for
Misplace your Manual? Want to view a Safety Video? Look up a Part for your ECHO Equipment? Do It All Right Here
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
SOURCE: First time to add gasoline, I am not sure how to
50:1 means 50 parts gas to 1 part oil
you can mix a quart of gas with 1.5 oz of 2 sroke oil
SOURCE: Need the air gap between
All magnetos work best with minimal air gap. Gap it with the thinnest piece of paper/plastic that you can remove from the gap. Spin it, examine flywheel for evidence of rubbing. If it's good, start it and zoom it a couple of times, shut it down and check again.
lp
