Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
Anonymous Posted on Jul 29, 2011
Engine runs great for 10 minutes and then stalls. Won't start until is sits 3-5 minutes. Replaced fuel lines, filter, cleaned carb., replaced spark plug. What else could be causing this?
Jim Parker
Level 3:
  • Master 1,041 Answers
  • Posted on Jul 29, 2011
Jim Parker
Master
Level 3:
Answers
1041
Questions
5
Helped
536179
Points
2636
Believe it or not, your gas cap is clogged up with dirt and debris. When a carburetor is unable to get a constant flow of air from outside, pressure builds up on the fuel tank. The fastest way to determine whether or not this is the problem is as follows.
As you are using your Mower, at that point when it begins to stall out, loosen the gas cap so that you release the pressure that is built up in the gas tank. If the engine begins to regain power, then you know it is a clogged gas cap. (Simply get a small wire and clear the breathe holes in the cap.) If the engine dies even after loosening the gas cap, then you may want to check to make sure the air breather is clean. ( A dirty air breather can cause the engine to over heat and stall out.)
If none of this seems to help, then it is probably a bad Ignition Coil.
Good Luck!
Jim
  • Jim Parker
    Jim Parker Aug 01, 2011
    mbliss792- Thanks for the rating!
    If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
    I will do my best to answer your questions about drywall finishing. However, it would be best if we could do a live Chat. I can answer any question you have if it involves getting a wall/ceiling ready for paint!
    Thanks Again,
    Jim
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 • Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
2answers
1997 subaru Impreza sport won't stay running . stalls after minute replaced Fuel pump,filter spark plugs wires ,cleaned injectors checked fuel pressure what next
check your grounds. I find many easy fixes by cleaning all the grounds around the engine bay. I would also check the ground at the fuel pump connector that wiring is prone to corrosion and breakage
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Kholer c Command 14 hp ohv engine equipped with carburetor solenoid will run fine for about 15 minutes then loose power, back fire and stall. Unable to start (sputters and backfires) unless let sit for 10...
if you take the carb solenoid of see if it has a black rubber cap on the tip. some times if you pull on it it will come off. if it does replace or cut the til off. don't try to force it off but if it comes off easily that may be the problem. as it is running it is sucked off by the vacuum inside the carburetor.
Jun 09, 2017 • Garden
1helpful
DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
