im not sure what you wat to do or are referring to if you are try to remove the password download dr freeware i have never used or had to use it it reads like it can remove passwords from any usb drives and if you are trying to use it but dont the basics Hope this helps you
insert this drive into a
usb slot
click start click on my
computer you should see your usb drive or
click start all programs
accessories open windows explorer navigate to your usb memory stick then go to
the information you want to back up select the information right
click select copy then back to memory stick select then right
click select paste
or select the imformation
hold the cursor on then drag it to the memory stick and drop it into it
or select the
imformation right click and send to the memory stick
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS,
FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB
Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista
/ 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file
system is damaged, has lots of bad data blocks)
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local)
account on your Windows system.
You do not need to know the old password to blank the
password.
Support Windows NT/2k/XP/Vista
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Hope this helps
Hope this helps you
only trying to be of assistance
Hope this helps
