Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when the cutting switch is on the lawn mower want come on. Is their any way to tighten the top belt and fix the cutting blade problem?
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
check the oil level might have low oil sensor on it. Also make sure the engine is clean (no built up oil and dirt on the motor itself or the fins on the motor)
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
The oil entered the cyliders when the mower was tipped at a severe angle. It will clear out after you run it for awhile. Check the oil level to make sure it is full. It could even be overfull and this is what caused the smoke. If it starts to run badly, check the spark plug or plugs. They could get "fouled" from the oil. Change the if the are black or covered with oil. It shouldn't have done any damage to the engine.
This engine has a badly designed combustion head that causes premature failure of the head gasket. The removal of the overhead cam and head is relatively easy with the engine mounted on the mower. Just remove the hood before you begin. I had the same problem, same symptoms (white oil smoke, mostly when turning or on an inclide-=left side downhill) after the second season of mowing. Made me mad when I got it apart and saw the incredibly stupid head design. Replaced the head gasket and am into my second season with the new head gasket with no more problems but I expect it to blow again at some point. Poor engine design. Easily fixed.
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size.
* For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size.
* If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
