Question about Gateway 507GR PC Desktop
I have a Gateway 507GR. Will not boot. Acts like it is going to powerup. Checks the drives, but never gets to the harddrive. Then the power supply slows along with the cooling fans. Replaced the power supply and it does the same thing. Tried hooking it up to a different hard drive and get nothing. Do I need to replace the motherboard?
  • John Appleseed Jul 27, 2011
    How long has the computer been doing this? And did it happen all of a sudden or have their been performance issues creeping up slowly?
    Master:
  • 469 Answers
A better bet would be to get a replacement computer. It's a P4 and way past it's useful life.
Posted on Oct 28, 2017
3 Suggested Answers
6ya staff
SOURCE:
micromend
George Brown
  • 748 Answers
SOURCE: Gateway GT5228 not loading Video
Checked memory?
Posted on Mar 27, 2009
Anonymous
  • 53 Answers
SOURCE: Gateway 507gr power issues...
Unplug the four-pin 12V ATX cable from the motherboard, and see if that makes it power up any better - it probably still won't work entirely, but see if it gets your cooling fans spinning. If so, you probably have a bad motherboard, with something shorting out the 12V power.
Posted on Sep 19, 2009
Wiring diagram for gateway 507gr
ATA drives usually plug into the drive ribbon cable; SATA drives usually plug into a connector on the motherboard.
Jun 29, 2014 | Gateway 507GR PC Desktop
I put a harddrive from my dell computer in my gateway dx200s. It booted up but I could not verify profit key. So I replaced the dell harddrive with the original gateway drive but now it wont boot. beeps...
all you need to do is put back the hard drive to the gateway, theres like a finger print that block the hard drive to come on but if you put back to its own i will come on...if you want to make it work in the dell you need to install a fress os...period...
May 01, 2011 | Computers & Internet
Press on button w/in 10 seconds goes to sleep mode.... Gateway 507gr.
Go into the BIOS, POWER and change the setting to what you want, generally power off not sleep
Aug 06, 2010 | Gateway 507GR PC Desktop
Sep 19, 2009 | Gateway 507GR PC Desktop
My Gateway 507GR PC desktop will not connect to internet
Turn off (unplug if necessary) your modem, router, and PC. Then power on the modem, wait a minute and then power on the router, then power on your PC, this should solve your issue if you have service.
Sep 08, 2009 | Gateway 507GR PC Desktop
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
USB devices not always working on Gateway 507GR
Truthfully, I've found this to be true about most USB ports -- when more than two devices are installed. I'm not sure there is a real fix for the issue. It's kinda like wifi. It works and it works good, BUT it's not 100% (all the time). It's just the nature of the technology.
Nov 19, 2008 | Gateway 507GR PC Desktop
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Oct 26, 2008 | Gateway 4525GZ Notebook
Keeps cycling to BIOS screen...
Hi pinkie890,
It sounds like there is a corrupt file (or files) somewhere in your Windows installation. I'm guessing that you might see a blue screen with white letters and numbers flash up briefly before it cycles back to the boot options for Windows.
It's actually bypassing the BIOS screen if you're seeing the Windows boot options, so chances are it's either a) a problem with Windows or b) a hard drive problem (physically).
My first suggestion, if you can't boot into Safe Mode, is that you boot off your Windows CD and do a Repair. When prompted, DO NOT format the drive in either NTFS or FAT32 (you should have an option that says 'Leave file system intact (no changes)'. This will install a copy of Windows over your existing installation but won't wipe out your personal data files. There is always a chance you'll lose your My Documents but that's slim. Hopefully you have a good backup done recently.
This isn't the optimal way to go, but it should take care of the issue. I would recommend doing what I've suggested, backing up your data, and then doing a fresh installation of Windows.
Let me know if I can be of further help. If you have access to another computer with a CD burner, download the free Ultimate Boot CD. Pop the case off your computer and check the hard drive to see what brand it is. At that point you can boot from the Ultimate Boot CD, run Hard Disk Tools, and then run the appropriate hard drive diagnostics tools for your particular hard drive brand. If the advanced/long test comes back with no error messages, you can rule out physical hard drive issues and be more or less certain that the problem you're experiencing has to do with your software.
Ben
Mar 13, 2008 | Gateway 507GR PC Desktop
Open Questions:
SBCglobal MAil TecH SuPPoRt {1^!855@^536^$5666}#O@ TECHNICAL call or contact SbCgLoBaL mAiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiLUSA Calling SbCgLoBaL mAiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiLUSA in General WhileI:855:,:5365666 is SbCgLoBaL mAiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiLUSA.call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiLUSA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Nov 20, 2019 | AOL Computers & Internet
See all Gateway 507GR PC Desktop Questions
Gateway 507GR PC Desktop Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
