The burner switch for that element will need to be replaced to fix this type of problem. To replace the switch, shut off the circuit breaker to the cook top and remove it from the counter. Remove the knob from the switch that you are replacing. Remove the burner box from the cook top surface. Remove the screws that secure the burner switch. Note the location of the wires connected to the original switch. Take a digital picture if necessary. Remove the wires and replace the switch. Make sure that the wires are connected properly. Reassemble and test the cook top. This information should help you fix this problem yourself. If you need more assistance, reply with additional details.
Thank You, it worked.
