Timex 27191 Wristwatch Logo
Posted on Feb 22, 2018
My timex ironman watch display fades and dissapears when I use the Chrono reset or start or time set or other buttons several times. Sometimes it resets the time to 12:00. Then the display gradually returns to normal intensity. Is it simply a battery problem or something more serious
4 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 09, 2009
SOURCE: timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
Anonymous
  • 2071 Answers
  • Posted on Jun 08, 2009
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Anonymous
  • 2501 Answers
  • Posted on Feb 11, 2010
SOURCE: Even after changing the battery, the display fades on a Timex.
It sounds like a short circuit somewhere in the watch. A visit to the authorised dealer sound necessary.
To find your nearest dealer go to "casio.com" click on "support" , then from the menu on the left, click on "repair and service" to find your dealer or service center.
Testimonial: "Thanks for the feedback. It's out of warranty and I'm not sure it's worth it. "
Anonymous
  • 2501 Answers
  • Posted on Jun 04, 2010
SOURCE: i m looking for a manual for timex ironman M586. I
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
The chronograph function on my husband's Timex Ironman Triathlon 30 lap watch disappeared the last time he reset the clock time. How can he find it again?
press hold set button till display blinks, then press mode key till you have display you want then press set key to keep selected display.
I can not get chrono to show
well, you did was good.. but when it happen again all you have to do is to push all button at the same time to reset it.. so that you dont have to take off your battery again..
My timex ironman 30 lap flix will not move to the chrono mode
From the time mode, just press mode button once and the word "chrono" will appear.
How do I get my indiglo timex watch off military time?
If it is the five button type I have (there are several) you hold "SET" until a field starts flashing. Then hit "MODE" until you see "24-HR" in the display. Hit "LAP/RESET" once and it should display "12-HR". Hit set again and you are done. Also note that timex has all manuals available online for free,searchable by the "module number" you can find on the back plate of your watch. Hope this helps.
8helpful
I press MODE button & get timer, occasa, alm1,2,3 but no CHRONO!!! How do I get to use the chronograph?
Setting Time after setting it, shows other type of settings 24/12 hrs, beep, chime and it shows Chrono where you can display or not. :)
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
