Televison & Video Logo
Anonymous Posted on Aug 30, 2008
I have a Dish for two TV's. I was watching one, came to watch on the main TV, the picture was a little square up in the corner. I pressed Format and everything went off. Now it says HDM1 in the upper left hand corner and Not Supported Mode in the center. I have tried everything and cannot see anything with the Dish but can switch to antenna and get my regular channels. I don't think anything bad is wrong, I have tried all the buttons, including Recover and nothing works. Thanks Pat Champion
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
49
Points
I unplugged the Dish connection, waited 15 seconds, and then plugged it up and it worked.
2answers
How do i send a picture text on iphone5
If you click on a picture, you see the square with the up arrow in the bottom left corner. Press that square. You now see a blue ball with a v in it on the right bottom corner. This means you can add more pictures, by going through your pictures and tap them. Not to many, because most mail servers allow not many pictures in one mail. then top right, press next. Then choose mail. Now you can enter the mailadres, subject and you can write the mail. Then top right press send.
Success
Sony bravia sound stuck
For a little more you can get a new better set with warranty. A no brainer.
2helpful
I have a Dynex TV and Dish Network receiver. Last year the TV worked fine, I don't think I changed anything, but this year the top of the screen is cut off when I watch NFL games. The top of the score...
You will need to press the "Format" button on your DISH remote This button will have a * on it. By pressing this button repeatedly, you can change the format of the screen set it to normal. Next grab the factory remote for your TV and try the different formats most likely normal will work best on this setting as well.
Daniel Busa
DISH Network
Customer Service
The inlaws pushed about every freaken button on the remote,now the picture on our tv is way too big ,and the heads and logs etc are no longer there help !!! please
This formatting issue can commonly be corrected by simply pressing the (*) button on your remote this button is also known as the format button and is located in the bottom left corner of the remote, which is also to the left of the zero button. You can change the formatting of the tv picture by pressing the star/format button until the format is corrected. I hope this helps!
-Kirstie DISH Network
1helpful
I have a samsung lcd 650 series tv and a dish network remote. I can use the remote to change channels and control power and volume to my TV. I cannot change the picture size and the picture on most...
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
1helpful
I am getting black borders top & bottom on some channels and side to side as well on Fox on my Dish Net receiver 322 to analog TV.
Hey there! Becki Barned from Dish Network customer service here. The black borders are usually caused by watching standard definition programming on a high definition television. Try to change the format on your tv. Either by pressing the * button below the 7, or trying a format or display button on the original tv remote. Hope this helps!!!
My Vizio VX32L "wide" control only seems to toggle between "wide" and Zoom" -- "normal" is not an option. I am missing the top and bottom of my picture. Is there a setting I need to adjust or what? I have...
We would be happy to help you get that fixed. On the DISH Network remote press the "*" button located in lower left corner of the remote. Press it repeatedly to rotate through different screen shape settings until arrive at the desired format.
We hope that this helps get your picture corrected. Thanks for choosing DISH Network!
Phillip Chang
DISH Network Customer Support Representative
I can only get snow on my tv screen
Does your controller turn the tv on and off?
CT-F683 TV fault
Press setup on your foxtel remote, go to systems settings, and look for "TV Type" menu, you can change settings there, your TV is a 4.3 (square) not widescreen. Its not a telly problem your just giving it the wrong signal.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
