SOURCE: lacie 1tb external hard drive
As a precaution, backup your data to another machine, in case the external drive is developing problems which would get worse and essentially "lose" your data. Does it do this on other machines other than yours? If so, it is developing problems, which, as said, could be deadly to data. If it doesn't foul up on other machines, then something is afoul with something on your machine. Various problems are reported with sleep mode wakeup. Could you disable the sleep mode function? You might see if there is an O/S update for your Mac which addresses this problem (waking up the USB ports & connected devices).
SOURCE: Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
SOURCE: Maxtor Basics 1Tb external hard drive not working
option 01. try the unit on another windows pc. if its the same. i am afraid you might have an issue with the device.
option 2 . you could remover the **** from the enclosure & fix it directly to the pc so that you can retrive the data. however this will have an impact on your warranty
SOURCE: video files on MyBook 1TB hard drive lag
So, if you move the file that won't load onto your laptop it then loads? If so can you plug it into another mac and see if it works on that one (if it works it an issue with your macs firwire ports and an os re-install may be needed or your card has been damaged) or can you try another hardrive with your mac (if this works you need to reformat your mybook)? I've bined a HD this year already, not good.
SOURCE: My 1TB HP simplesave hard drive is not working
i have the exact same problem..... where you able to fix yours?
