It may shutdown when it gets too hot. Toshiba Satellite had some problems with this a few years back which involved a class action lawsuit. I had one of the computer that experienced problems and lost a lot of material which had not been backed up yet. I received compensation as part of the class. The lawsuit was settled, but I notice that the Satellite that I purchased since then will shut down automatically when it gets too warm. It helps to put it on a cooling device and I also turn on a regular fan and point it toward the computer when I can. If it is inconvenient to do any of this, I turn it off periodically to let it cool down. That way, I don't lose any data. Of course, I back up all data frequently.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
