When you turned off the water to remove the old faucet did you have to turn off the water to the whole house or was there cut off valves going to the tub. Did you install cut off valves for the tub and forgot to turn them back on before trying the new faucet. What type of faucet did you install? Whats the make and model. Its possible something got caught/dropped in the pipe when you were installing the new faucet and is now blocking the flow of water.
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: just installed shower and faucet in bath tub when
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
SOURCE: New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
SOURCE: I just installed a Glacier Bay tub/shower faucet
Hopefully you still have the directions - the diverter isn't set correctly.
you will have to be more specific like what exactly did you install?, brand name?,model/serial number and then i can help you better:)
