Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA the leads from your
((motherboard to your hard drive)) make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error if
this fails to fix the problem
another
possible reason could be a memory dump you might be running to many programs at
the one time placing to much strain on the CPU also you might not have enough
RAM random access memory to check what is running when your computer is running
scroll to the bottom toolbar right click select task manager applications and
processes if you see something you dont need running select end now to check
how much ram you have click start right click on my computer select properties
you will see all of your computers details another way to check
how much RAM you have click start all programs accessories system tools system
imformation all of your computers imformation will be there
try uninstalling a few unnecessary programs then click start run
type cmd then type chkdsk/r/f which will scan for and attempt to fix
any bad sectors and automatically fix any corrupt files on your hard drive this
will schedule on a restart don
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory hope this helps
to shutdown or fail to detect your Test your PSU or replace it if your power
hard drive
extensions,IDE,SATA
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or
make
secure connections and are not faulty even the electical extensions or just
hope this helps
hard drive
extensions,IDE,SATA
the leads from your
make
hope this helps
to shutdown or fail to detect your hard drive
extensions,IDE,SATA
there probably old and faulty
make
secure connections and are not faulty even the electic extensions or just
hope
this helps
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope you find this helpfull
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
