I've been looking for a replacement for the Seiko SNAE93p1 and have seen the replacement for this in several places. I only remember because it has a red and black band similar to the one on the watch I'm wanting, and I figure that I should get a replacement band when I buy this new watch, as the synthetic bands on Seiko watches tend to break after about 3 years or so.
Watchbands.com has it for $65 I believe. watchbands com
SOURCE: INSTRUCTION MANUAL
Your watch is fitted with SEIKO 7T62 quartz movement. Follow this link to download users manual:
http://www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
Rate me, please.
SOURCE: Changing time
Go to this link - there are two different SNJ series guides available, hopefully one will be right for your model - check the number on the back. http://www.seikousa.com/Faq/OperationGuide.aspx# If checking that all the settings are correct and resetting everything by taking the battery out does not cure the problem, then the watch needs service - better take it to a dealer to remove the battery too as they will stock the seals required which are important, and the tools to make the job easy and safe. Hope this helps :)
SOURCE: Seiko Sportura SNJ007 chrograph watch instructions
Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
http://www.seikowatches.com/support/ib/index.html
SOURCE: i have a sector 600 series with a black rubber
Here you will find Sector contact details:
http://www.sectornolimits.eu/#/eng/contact
And here is the link where you can find nearest Sector:
http://www.watchservicecenter.it/
You have to contact them and ask for the strap/bracelet you are after.
Rate me, please.
