Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
Product type (AE) Motherboard
Form factor Micro ATX
Width 9.6 in
Depth 7.6 in
Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
64-bit Processor Compatibility Yes
Mainboard processor socket LGA775 Socket
Mainboard / Multi-Core Support Dual-Core / Quad-core
Chipset Type Intel G31 Express
Data bus speed 1333.0 MHz
Storage key information Serial ATA-300 , eSATA port
Power connectors 24-pin main power connector , 4-pin ATX12V connector
Processor
Installed Qty (Max Supported) 0.0 ( 1.0 )
Memory
Cache Memory Type None
Supported RAM Technology DDR2 SDRAM
RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
Supported RAM Speed PC2-6400
Video
Graphics Controller Intel GMA 3100
Video Memory Dynamic Video Memory Technology 4.0
Audio
Audio Output Sound card
Sound Output Mode 5.1 channel surround
Audio output compliant standards High Definition Audio
Telecom / Networking
Modem None
Networking Network adapter - Ethernet , - Fast Ethernet
Features
Hardware Features Intel Fast Memory Access Technology
Expansion / Connectivity
Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
Additional connectors (optional) 4 x Hi-Speed USB
Miscellaneous
Included Accessories I/O back plate
Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
Software Included Drivers & utilities
Windows Vista Readiness Certified for Windows Vista
The Intel board is a discontinued product but is a better board than asus
