Runs 2 days here a clickin noise ind strip hear blower area then burnd transformer out
runs 2 days here a clickin noise ind strip hear blower area then burnd transformer out
seems to be in handler unit area maybe a relay on high volt side
Replace the transformer with a 75va resettable transformer.
Check all wiring for a loose connection at the unit and the disconnect and the breaker panel.
Double check ground wires.
Check the low voltage side for a back feed short from a faulty component.
Could be caused from a bad thermostat wire.
Do a continuity reading on stat wires to look for a short.
Do an amp draw reading on the unit to determine an increase in amperage.
