The thermal fuse, sometimes called a "thermister" is a device that is usually located behind the rear panel in the freezer. It looks like a wire with a small thing on the end that is secured to the coils behind the rear panel. You will need to remove all the contents of the freezer and remove the rear panel in the freezer...You most likely are going to need to replace it, so getting a new one before you start taking everything apart will be a good idea..You'll need the model # of the fridge etc. Find an appliance parts dealer to acquire the new part which should be fairly inexpensive.. Search "refrigerator thermal fuse" on YouTube and you should find a few video's on what to do and what to look for..Good luck!
SOURCE: the refrigerator is not cooling properly , only
If your refrigerator is not cooling, the problem could be
any of the following, follow the steps below one after the other to fix
the problem of your refrigerator not cooling.
First of all, the
most simplest thing to do is to check the temperature.
It might have happened that the temperature control may have
been turned off unknowingly, which is the reason for the problem. So if
that's the issue, just set the refrigerator at 37 degrees and you are
all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A
frost build up, specially on the ceiling of the freezer, is a sign of
problem in the self defrosting system or damaged gaskets of the doors.
Therefore, check if the refrigerator is facing such a problem and
defrost the refrigerator. It would not cool well if the defrosting is
not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling
well. What will happen in case if the condenser is dirty is that it will
cut off the extra load. That work is done by the thermostat on the side
of the compressor in case the refrigerator heats more than usual. To
rectify this problem clean the condenser coils using the vacuum cleaner.
These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the
refrigerator not cooling properly, because if the level is not right,
the door of the refrigerator may not close correctly, causing cooling
problems. If this is the case, it might be necessary to ensure that
refrigerator is at level and is slightly tilted back. Do some adjustment
to get that correct level using a wooden block or see if the screws on
the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will
definitely result in frost build up and that won't allow the door to
close properly, thus the problem of refrigerator not cooling. In
addition to that there can be a problem in the door even if the level
and other things are fine. You would need something to do about the door
then. May be loosen the hinges and fix them in order to get the correct
position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator
fan is not working properly. This is because then there will be no
airflow to the freezer or the other sections of the refrigerator.
Confirm if both the fans are working well by listening to the sound
emitted by them. There is a possibility that one may work and the other
wont. For that, may be you would have to look for a blockage or
something in the one which is not working. Even after doing this you do
not find any problem in the fan, you may need to replace it. This are
are the general procedure for troubleshooting refrigerator not cooling.
with all this, you should be able to identify and fix the problem.
Take
care.
SOURCE: refrigerator not cooling! freezer works
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
