My washer is not draining - we changed the motor and cleaned the drain. now could it be the CCU?
Hi lauraeuschwa,
I believe your drain pump filter is just clogged. The drain pump is
trying to pump the water out before the Spin cycle, but can't. Usually
this is caused by a foreign object that is obstructing the impeller. See
my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it
does not, then you may need to replace the Drain Motor. Which is a easy
task.
Kind Regards :-)
* If this solution helped you, please rate it
Sorry use this link:
http://www.fixya.com/support/r9744345-ac...
Rs.2000 credit and 30 day support Advertise Now!
www.Google.com/AdWords
