Peg Perego John Deere Turf Tractor Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you adjust the seat - Peg Perego John Deere Turf Tractor
Adam Fjeld
Level 3:
Genius:
  • Peg Perego Master 1,508 Answers
  • Posted on Jun 06, 2012
Adam Fjeld
Peg Perego Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542588
Points
1761
You have to remove the two screws from under the tractor at the rear, then lift up the green part of the seat then you'll seel the red knobs to loosen to adjust the seat forward or backwards
The front seats for our 2003 Escalade will not move forward or backward and the heat control for the front seats will not work.
Does your Escalade have memory seats ?
There are 2 options of power seat systems available in full size trucks. The 6 way driver and passenger power seats, and 8 way driver and passenger power seats with driver memory. For the driver memory seat operation refer to Memory Seats Description and Operation . Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
3answers
Driver side electric seat is stuck in the far forward position and won't move. How do I move it manually or fix the motor.
Auto Repair: How to Replace a Power Seat Motor - YouTube
? 1:44
https://www.youtube.com/watch?v=EDh-0rs5Fjo
Oct 26, 2010 - Uploaded by automdvideos
Auto Repair: How to Replace a Power Seat Motor ... 2007 - 2008 Ford Expedition/Lincoln Navigator Driver Bottom Install Video ...2003-2006 Chevy/GMC Seat Cover Install 1 of 3 - eBay Ready ...2000 Ford Explorer Front Seat Track Stuck Motor Repair - Duration: 4:39. by cubmancan 4,959 views. 4:39.
Drivers seat is dead! No power seat or heat. - TheDieselGarage.comwww.thedieselgarage.com/.../96465-drivers-seat-dead-no-power-seat-hea...Mar 22, 2010 - 2003-2005 Chevrolet Avalanche, Silverado, Suburban, Tahoe 2003-2005.... Power seat on driver side didn't work.....passenger did! Neither ...DANG electric seat ' Chevy Truck Forum ' GM Truck Clubwww.gmtruckclub.com/forum/threads/dang-electric-seat.2990/Apr 27, 2006 - 10 posts - ‎7 authors'03 Tahoe My driver seat just stopped, of corse not where I need it, the ... I have a 2003Tahoe and both heated seats are not working. ... with my seat heater on the drivers seat in my 03 Avalanche, it turns ... The driver's side on my Silverado gets way warmer than the passenger side. ... Frozen New Member.Power Seat Problems?? - Tahoe Forum - Che
The six way power seat on my 2005 suburban has an issue. When I turn the motor off and remove the key the motor goes to it's down and back position but continues to run. And it doesn't respond to the...
The first place to start would be to have the dealer or someother qualified repair shop , that has a professional scan tool read DTC'S - diagnostic trouble codes in the driver seat module ! The seat adjuster motors are controlled by the driver seat module through the adjuster motor control circuits. In an inactive state both of the motor control circuits are grounded within the driver seat module. In an active state the driver seat module switches the appropriate motor control circuit to battery positive voltage. The direction of the adjuster motor rotation is determined by which of the motor control circuits is switched to battery positive voltage while the other remains grounded. During adjuster motor operation the driver seat module also monitors the current flow through the motor control circuits.
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 , B1850, B1860, B1960, B2355, B2365, or B2375
B3962
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Driver seat module
• Driver door module
• SEAT 30A circuit breaker
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the driver seat module and are used to determine the seat position when storing or recalling memory settings. The horizontal, front vertical, and rear vertical adjuster motors use hall effect type position sensors. The hall effect position sensors are supplied with battery positive reference and ground circuits from the driver seat module. The position sensor signal circuits are supplied battery positive voltage through a resistor them monitored within the driver seat module. During adjuster motor operation the hall effect position sensor provides a single pulse for every revolution of the adjuster motor shaft. The driver seat module counts the pulses from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings. The recline adjuster motor is equipped with a potentiometer type position sensor. The recline motor position sensor is supplied with it's own 5-volt reference ground circuits from the driver seat module. The recline position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39 - 4.58 volts and is determined by the wiper location on the resistor within the recline motor position sensor. The recline motor position sensor signal circuit voltage level is used by the driver seat module to determine the seat recline position when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver's door provides inputs to the driver door module. Battery voltage is supplied to the memory
Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
4helpful
2answers
2001 VW Beetle. The driver's front seat adjuster
I'm assuming you have manual adjustment seats. There is a spring underneath the seat that locks the end of the lever into corresponding notches in the seat frame rail. That spring has either fallen off or broken.
2helpful
How do i remove the front seats of a 1998 Pontiac Grand Prix?
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
2answers
Seat adjustment
Passenger seats are usually manually operated from a latch or bar under the front of the seat. the seat back should have a lever between the door and edge of seat to make adjustment pull up on lever push back on seatback.
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
