SOURCE: I have a 20hp sears lawn tractor with Kohler
give me the model# and serial# located on a tag under the seat.
i will tell you the trans/belt #.
mower_man
mowermc&aol.com
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
SOURCE: Looking for manual for Craftsman 917.256552 15HP
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
SOURCE: Kohler 22 HP Engine 2 cyl craftsman lawn tractor
Have you pulled the filter out to see if it's clogged? The easiest way is to remove from the system and blow through the filter. If you can blow through easily then you might have a bad fuel pump.
Mike
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
THE WHEELS TURN LIKE BECAUSE IT IS POSITRACTON YOU MAY HAVE A TRANSMISSION PROBLEM
