Brinkmann Smoke 'n Pit Smoke King 805-2200-0 All-in-One Grill / Smoker Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got a used smoker tonight - a smoke n pit smoke king 805-2200-0 - are the small holes in the top and bottom all the ventilation needed for the smoker or am I missing parts? Also, is there a place for a thermometer?
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jul 15, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2105112
Points
14643
No, you're not missing any parts. What you see is what you get. There is a hole for a thermometer in the door, but for whatever reason, Brinkmann didn't include that with the smoker. To help you further, I have included a link to the Owner's Manual for your "discontinued" model smoker.
You can download and print the manual for future reference.
http://images.brinkmann.net/docs/pdf/805-2200-0.pdf
Hope this helped you.
Need wooden handle halve for my Brinkmann Smoke 'n Pit Smoke King
https://www.brinkmannpartsworld.com/models
Get the model number from your Brinkmann. Click on link above. Enter model and look for part listing.
You can order it direct.
Semper Fi,
Z
Lighting access hole
Top of the pit lol get you a long lighter turn the knob to a small gas leak stick the lighter in the grill and light very easy
Aug 22, 2012 • Grilling
We have a brinkmann smoke 'n pit charcoal grill $ smoker- the manual says to cure it- how do we do this and for how long? :-)
By cuing, they mean burning it for an hour or 2, before using it to grill or smoke food. Coat the grill grates with a light coating of vegetable oil, before firing up the charcoal. Maintain a temperature of 325 - 350 degrees F for half an hour with the hood closed and a half hour with the hood raised.. After that, the grilling part of the grill - smoker should be cured. The smoker part, other than cleaning, doesn't need much curing. As the temps for smoking don't exceed 225 degrees F.
Hope this helped you and Happy Grilling!!
Jun 28, 2011 • Grilling
Where can i get parts for my brinkmann model 805-2200
Go to this link, then Find My Grill, find your manual and part and you can order here also. Hope this helps.
Normal 0 http://www.brinkmann.net/home.aspx
How to maintain a tempature of 225-250 for long periods of time with no accessories?
There is a small circular shaped plate on the bottom and the top that has holes in it. These holes are there to align with similar holes in the body of the smoker. As you stoke the charcoal and get a good hot coal bed then you can adjust the amount of fresh air that makes it to the fire. This will help you maintain a more constant temp. Though you will need to constantly watch to see if it is maintaining. If not you will need to adjust accordingly. Hope this helps. Good luck.
3answers
Not enough heat
I have not gotten a solution from FixYa, but some of the responses to other questions have revealed my plan of modification to the unit. No i would not like the Premium Assistance Plan, yet.
Thanks
Brian
1helpful
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
4helpful
Char-broil water smoker
first, a charcoal fire in bottom tray, then a pan filled with hot (boiled) water above it, then the meat on top tray, then keep lid on a long time (hours) without peeking and remember to keep charcoal topped off. you should also soak hardwood hickory sticks in water for a day or 2 and wrap in aluminum foil with small holes punched through and place on top of charcoal to provide smoke. usually a large chicken is done in about 4 hours.
Top Brinkmann Grilling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
