Behringer Europower Pmp1000 Powered Mixer Pmp Offer Logo
Anonymous Posted on Jul 12, 2011
I need the diagram of behringer europower pmh1000
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Jul 12, 2011
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2249786
Points
16163
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Testimonial: "thanks alot.hope that i can help you some time"
Shahid Aziz
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 193 Answers
  • Posted on Feb 18, 2018
 Shahid Aziz
Master
Level 3:
Loyalty:
Answers
193
Questions
Helped
148477
Points
1389
Behringer Europower PMP500 using 1/4 inch cables for speakers?
Question edited for maker.
Question moved from Musical Instruments to correct category.
Running a 1/4" cable has no bearing unless you are trying to run a hundred yards of cable. Check your plugs wiring and connections to the unit. Here is the manual.
https://www.manualslib.com/manual/573726/Behringer-Europower-Pmp500.html?page=4#manual
3helpful
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
1helpful
I'm a retired electronic tech. and like to know all the in's andout's of this latest purcheses. Like the input ports 13 to 16 on PMP1000, what are there spec's? So I would appreciate a...
The PMH1000 is VERY close to the PMP1000 and circuitry is almost identical:
Scroll down to "Get Manual" and click on it to download... IGNORE other downlooad links. Also please read my tip about a hazard for PMP mixers regarding using SPeakon to 1/4 inch plugs for speakers. The tip of channel B is the hot... BUT the sleeve of channel A is hot and grounding it can blow channel A amp. This has class "D" switching power amps which are efficient. The power supply is a switching type that runs off the line voltage. Working on the supply requies using an isolation transformer for personal safety.
1helpful
2answers
I need a service manual with a circuit diagramme to repair one of these with an input circuit fault.
GO ONLINE AND CHECK BEHRINGER EUROPOWER EXP3000 STEREO POWER AMP. YOU MAY GET SOME HELP THERE.
1helpful
2answers
Hello! I have a Behringer EUROPOWER PMH 1000. But the power board burnt source. What do I will acquire another, or fixable?
Often teh power supply fails because of other problems. Unless the board has flame damage the parts that are defective can be replaced... Getting some of the parts that are special can take time. Most of the components are available at many sources however. The SPS400 power supply can be repaired.
Here is link to schematic that should have the SPS400 as well as the rest of the PMH1000 on it.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
