SOURCE: 2003 Geely 50cc Moped wont start without starting fluid.
Both types would use fuel enrichment to make the fuel/air mixture richer for cold starts. Motorcycles deliver extra fuel to the intake through small holes in the intake bore when the choke is activated. When cleaning, use something soft like a plastic broom bristle (not metal wire) to avoid scratching the inside of the jet or passage.
Good luck,
Techjoel
SOURCE: peugeot jet force 50 engine cuts out on overrun
when the engine dies pull out the spark plug and earth the plug on the metal part and turn it over dont hold the spark plug as you will get a shock if the plug sparks you know the ignition system is working.if you have no spark do a compresion test to see if there is a problem with the engine.if that ok you will have a fuel problem make sure the breather on the fuel tank isn blocked or trapped.
SOURCE: Low-end Bog
tried this on the carb turn the mixture screw in a 1/4 of a turn
Testimonial: "I runnin 32:1 with ninety two octane gas"
