Please check if you can access the card on a computer?
If you could format the card from a computer and choose the file system to be fat32.
Also make sure that the contacts are clean and make sure that the slot you have to put it in the camera is cleaned too. If the problem persist the problem could possibly be the contact on the camera not properly touching the contacts on the card that's why it's not able to remove the permission from it.
It would be better to have a camera technician look at it for you as it would involve opening the camera and cleaning or possibly replacing those contact pins.
Hope this helps!
I can access it on my computer and that is the setting it shows. Tried to reformat it there but then get write protected message. It works fine once I get it to go away until I remove it again. I had to get a card reader because right away the port to connect to the USB broke. So the card is in and out usually daily as I am active on ebay. I have had success cleaning the card but see no way to clean the port. Can the cards wear out? Sounds like I need to take it some where.
Thanks
