I suspect there is water leaking in to the sensor unit circuit located just behind the sensor. The Casio service would change the sensor, and all the gaskets in the watch. Then do a water pressure test on the case and etc. to make sure no leaks. I do not think you can service this yourself. You would have to know exactly the parts to buy and have the tools, and the pressure chamber to verify the gasket seal performance.
You should send it to Casio with a copy of your complaint. Look up Casio on the Internet and choose your country. Go to support to find the service address and instructions of where to send the watch. If you email them it can take a few days till they respond. They will send you the specific instructions. Their service is terrific. I own a number of their high end watches. In fact I have one with them being serviced. Sometimes I have broken the glass because I am rough with my watches at times.
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
SOURCE: Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
SOURCE: WHEN I GO DIVING HE DOESNT VANT TO SAVE DEPTH INTO
Perhaps you have not instructed it to start recording?
I cannot gain access to the instructions for you watch as the site require me to enter the watch number.
If you have not got the instructions, go to "casio.com", select "support" , then "manuals", then "watches"; agree terms and conditions; select "archive...".
Enter the number off the back of your watch and download instructions.
Testimonial: "thank you very much!!"
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
SOURCE: I have a casio sport
I had this problem with the Casio 2926 at midnight for many weeks and no matter which buttons I pressed, it carried on.
I solved it on my model, by going into alarm set mode (AL) by toggling button on lower left of watch face. Then using button on lower right, cycle through all (5?) alarm options and also check the tiny screen new the rim at top right of watch face marked with SNZ ALM SIG. If a little black box shows up on this screen, switch off the alarm or snooze, by pressing the button on top right.
Otherwise go to Casio and go through their instructions. The watch is not designed for easy use.
