Hi shadyron11,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting
enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If
all of these come back OK, and it still gives the same problem, I'd
suggest replacing the inlet valve (Found on the opposite side of the
inlet pipe - inside your Dishwasher), could also be a pressure switch
(Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
