SOURCE: Toshiba Satellite A45-S250 DVD/CD Drive
The CD drive is held by two screws on the bottom near the small handle you use to pull the drive. Take out these two screws and it should slide out rather easily. If it doesn't check to see if you removed the right screws. It doesn't matter how many screws you remove, just so long as you put them back in.
SOURCE: HOW TO GET TO THE RAM IN A45-S250
You will find the memory on the Toshiba A45-S250 under the keyboard. Snap of the grill that also has the on/off button on it, just above the keyboard. You will find two screws holding down the keyboard and another screw near the middle holding down a small silver piece that is holding down the center part of the keyboard. Lift the keyboard from the screen end toward you. Memory is located under a clear plastic flap.The power should be off and the battery removed during this operation. Be sure to touch some metal piece to ground yourself also. Good luck.
Testimonial: "this info came after I found it on toshiba website. It is accurate, mission accomplished."
SOURCE: toshiba satellite a45-s250 bios password removal
try this man:
first: download hiren's boot cd
Second: burn it using nero
third: boot it at hiren's boot cd
fourth: after booting from the hirens bootcd choose bios/cmos
fifth: use bios!
sixth: browse for any passwaord there, but do not use the blaster, it can cause system failure, i think the admin password for a45-s250 is ami..
hope this helps you
Hi vytas_ceponi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Do you have desktop speakers or do you have surround sound speakers? You may have to go into sound options and select the output in the control panel.
