i am going to guess that it won't restart immediately after it dies either. It sounds to me like an ignition module going bad. it gets hot then cuts off the spark, once it cools down it starts and runs again until it gets hot again
It sounds like your ignition coil is overheating. Once it cools down it will fire properly until it gets hot again. Replace the ignition coil and you should be all set.
You need to find oput what you loose when the truck shuts off, all you need is Air, Fuel , and spark to run one of the three are droppuig out when it stalls and will not run. Chech the carb for gas it sounds like you have a weak fuel pump.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
