Jenn-Air JGD8345 Gas Cooktop Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is 2 years old. I had electric before and it worked very well.
Anonymous
Level 3:
  • Master 2,006 Answers
  • Posted on Jul 06, 2011
Anonymous
Master
Level 3:
Answers
2006
Questions
Helped
593169
Points
6261
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
  • pshears1 Sep 19, 2011
    I have the same problem with my downdraft. It works for 15 to 20 minutes then shuts off and I have to finish in oven. There are no clogs in the vent pipe and is less than 10 feet with only two short elbows which is within manufactures installation guide.
Can I remove the downdraft equipment under my jennair electric cooktop and still use my cooktop?
It is possible to remove the downdraft equipment from underneath your JennAir electric cooktop and still use the cooktop, but it depends on how the downdraft equipment is attached to the cooktop and whether there are any other issues that may arise from removing it.
Before attempting to remove the downdraft equipment, you should consult the user manual or contact JennAir customer service to ensure that it is safe to do so and to obtain any specific instructions for your particular model.
Some potential issues to consider when removing the downdraft equipment include:
  1. Airflow: The downdraft equipment is designed to help draw smoke, steam, and odors down and out of the kitchen. Without it, you may experience reduced airflow and ventilation, which could result in lingering odors or smoke.
  2. Heat distribution: The downdraft equipment may also help distribute heat evenly across the cooktop surface. Without it, you may experience hot spots or uneven cooking.
  3. Stability: The downdraft equipment may provide additional support or stability to the cooktop. If it is removed, the cooktop may become less stable or secure.
If you decide to proceed with removing the downdraft equipment, it's important to follow all instructions carefully and to take appropriate safety precautions. You should also be prepared to address any issues that may arise as a result of the removal, such as by using an alternative ventilation system or adjusting your cooking techniques to compensate for any changes in heat distribution.
If you're unsure about whether or how to remove the downdraft equipment from your JennAir electric cooktop, it's best to consult with a professional technician or contact JennAir customer service for guidance.
Nov 29, 2022 • Cooktops
How to replace a fuse?
It is fused through the house breaker box.
1helpful
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Downdraft cover and grill grates
i bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
2answers
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
1helpful
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
