In a 2004 Mercury Mountaineer, the fuse for the dashboard lights and taillights is typically located in the fuse box under the dashboard on the driver's side of the vehicle. The exact location of the fuse and the fuse number may vary depending on the specific model of Mountaineer you have.
To find the correct fuse, you will need to refer to the owner's manual for your vehicle. The owner's manual should have a diagram of the fuse box, which will show the location and function of each fuse. Alternatively, you can also check the label on the inside of the fuse box cover, which should also list the function of each fuse.
Once you have located the correct fuse, you can use a fuse tester or a multimeter to test the fuse to see if it is functioning properly. If the fuse is blown, you will need to replace it with a new one of the same rating. It is important to use a fuse with the correct amperage rating to avoid damaging the electrical system. If you are unsure which fuse to use, it is recommended to consult a professional mechanic or refer to the owner's manual for guidance.
I have a 2003 mercury mountaineer with a dying battery problem and we narrowed it to fuse 1 and 29 and they are labeled PJB in the owners manual....if you find out what that means I would like to know too. I don't know if that will help you any
I think you should go for manual first after that it will be easy for u to solve your problem. I had visited this site past 2 months before for my vehicle and find it quite helpful may be you will also get something useful here Mercury Mountaineer 2002 2005 Factory Service SHop repair manual Download
Initially look at the fuses. The windows will have their own fuse and the radio may work on the same fuse as the gauges. The fuses must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown ones. A small pair of pliers will ease removal of the fuses.
they can go bad-swap it out with another that you don't need, just to try and see if it is the relay-listed are relays that might only control, for instance, the rear window defroster-generally, relays are all the same, some just get used heavily and some don't (i.e., ABS)-worth a try
