Vacuums Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a way to adjust them to improve accuracy?
  • Anonymous Mar 31, 2014
    After the 88.88 appears the ERR appears instead of 00.00. I have tried changing the battery, but to no avail.
    Would be very grateful for a solution.Many thanks.
    Kate Bettison
    After the 88.88 appears it shows ERR instead of 00.00. Would be very grateful if you could provide a solution.
    Many thanks,
    Kate Bettison
Anonymous
Level 2:
  • Expert 300 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Answers
300
Questions
Helped
98754
Points
787
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
I have a pool vac ultra in a variable depth pool. There seems to be too much buoyancy in the unit, it keeps on going up on one wing as it travels up the slope between deep end and shallow end.
Sometimes you need to burp out any trapped air under the vacuum as you place it in the water. Trapped air bubble can cause that. I have had to fasten a light diving weight to mine once before I figured it out.
Dec 22, 2016 • Vacuums
Weight watchers electronic scale showed overload after I inserted batteries. Now the scale is no good. I never got to use it. What can I do?
The scale is not able to find ZERO and this can be checked by looking at the feet and see if any are stuck down, they have sensors in the feet and the unit checks and calibrates the sensors when it is powered on. .See if you can pull on the legs a little bit and then try it again.
Sep 11, 2017 • Vacuums
1helpful
Weight of Hoover Lark H9560
the weight aprox is 45 lbs.
God bless you
Need instruction manual. When weighing a container....how to set the weight so you do not have to subtract container weight
You have provided very little information and your question ended up in the vacuum cleaners category. I know your question is related to a scale so I will take a stab at a solution. If there is a "Tare" button, put your container on the scal and press the tare button, you should now see zero for the container and the scale will begin measuring the weight when you add something to the container.
Jun 27, 2011 • Vacuums
I just need to get a copy of the instructions for the 5758BL Biggest Loser Scales.
Taylor has a number of scales available in The Biggest Loser series for which they make available a link to the Instruction Manuals. See here:
http://www.taylorusa.com/catalogsearch/result/?q=biggest+loser&x=0&y=0
Here are two examples:
The Biggest Loser 7334 Weight Management Electronic Scale with Goal Tracking
http://www.taylorusa.com/media/IBs/7334_ib.pdf
Taylor The Biggest Loser 73343 Lithium Electronic Scale
http://www.taylorusa.com/the-biggest-loser-lithium-electronic-scale.html
Unfortunately after browsing their site I found nothing close to the model number you provided. If you see a model that is similar in looks and features suggest you see if the instructions for that model are of use to you. You may also find there FAQs to be of assistance:
http://www.taylorusa.com/faq-scales
Alernatively send an inquiry direct to Taylor Precision Products:
http://www.taylorusa.com/taylor-support
Apr 23, 2011 • Vacuums
How may litres in a kilogram
A litre is a measure of volume.
A kilogram is a measure of weight.
However, 1 litre of fresh water at 4 degrees Celcius weighs exactly 1 kilogram.
Hope that helps.
Mar 20, 2011 • Vacuums
If I double a crock pot recipe (4lb. pork loin instead of 2 lb.), do I double the cooking time?
Somehow this problem ended up under Vacuums!
However- I will pass along what my wife says: "Almost 2 times as long"
Same with Turkey in the oven-- She takes the weight, and multiply's the pounds by 20 minutes on the Turkey-- Thus twice as much weight takes twice as long..
I hope this helps-
If not-- try 'Kitchen' or something closer-- or try going on line?-- maybe compare 2 different sized crock pot recipe's of the same or similar meat?
Mack B
Jan 27, 2011 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
