Question about Jenn-Air JED8430 Electric Cooktop
Hold down brackets ?
I am installing jenn-air electric downdraft cooktop--model jed8430bds.
the installation instructions do not show any type of hold downs. the underside of the cooktop does not have any type of mounting channel.
no mounting brackets supplied with cook top.
so--how do i mount the cooktop to the counter???
thanks
  • reuben218 May 02, 2009
    how to mount to counter top
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
supply
between white - black 220v
between white or black - ground 110
cooktop
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
connect
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Regards
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Downdraft fan not pulling test card down
whats you model number as does it sound like fan is running and what do you mean by not pulling test card down did you just install it or had it for awhile i will try to help
Jan 02, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
259 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
