Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Aug 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Purchased a used LT 1000 42" 17.5 IC OHV and I
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Craftsman Master 1,669 Answers
  • Posted on Dec 12, 2017
Clyde Ottaway
Craftsman Master
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490815
Points
2465
The noumber you saw on the body of the mower should be it go on lne LT 1000 17.5 ic ohv and see what comes up you may find it that way i hope>
5 Related Answers
Anonymous
  • 138 Answers
  • Posted on Aug 18, 2009
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Anonymous
  • 157 Answers
  • Posted on Sep 18, 2009
SOURCE: MTD Riding Mower with 21 hp OHV 1/C
the valves need adjusting
Anonymous
  • 95 Answers
  • Posted on Mar 17, 2010
SOURCE: Need a replacement splindle for Sears LT3000
The complete spindle is called a mandrel on sears site part number 192870 $47.24. You can also get the housing all by itself and reinstall the shaft and bearings into it part number 187281 $24.60. The shaft is what the blade attaches to and can be purchased separate part number 192872 $17.84. All these parts can be purchased at a local Lawn repair shop for less money just take in these part numbers or your model number with you.
lnbn1975
  • 204 Answers
  • Posted on Aug 15, 2010
SOURCE: Dear Sir, I noticed that you
If you do not get any help here, try:
mytractorforum.com
You will have to register to post your question, but it is a free site and you may be able to find your answer without registering.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Aug 14, 2011
SOURCE: a cable is loose that will not allow me to engage
Tightening up a stretched cable is impossible. If the cable is NOT adjustable to shorten it and make it tighter, then you will need a new one. Here is a link to one. I searched all the parts diagrams in your manual for the cable and find it was NOT listed. I hope this helps as I have researched your problem. Go here:
http://amcpartsstore.com/FSP-Deck-Blade-Engage-Cable-Craftsman/M/B0014G6T1S.htm
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
Phone locked
what kind of lock did you mentioned here?If it is Network lock, then you can unlock your phone using unlock code from the site TheUnlockSpot.com here you need to specify your phone model,country,Network name to which it is locked,IMEI number of your phone.
1helpful
I recently purchased a Canon EOS Rebel T3i SLR camera (July 2011) and already I am encountering a problem called "Err 05 the built-in flash could not be raised." Does anyone know how to resolve...
Hey Leo,
Unfortunately the problem you've mentioned is quiet common with your particular model.
Here's what Canon recommends, on its website.
-Turn the power switch to < ON > to turn on the power again.
And, if that doesn't work. Buddy, you'll have to drop by a service center. Hurry up, or you'll run out on the warranty period.
Toodles,
Rebel K
3answers
Hello, 2 years ago you have posted the info on how to repair ws-65869 "This model uses a single convergence IC chip---- STK-393-110. The chip needs to be replaced and there are about a dozen...
Buy the IC online search using google
The resistors almost never need replacing. But each is marked with a value in Ohms.
They are low Ohms like 2.2Ohms or 3.9Ohms.
If one is bad it will look burnt usually.
Install the IC chip and if one color won't adjust check the resistors with an Ohm meter.
either the ohms is written on the resistor or there is a color code on eem
Best of luck
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
A cable is loose that will not allow me to engage the blades, how do I reattach the cable. it is a craftsman Lt 1000 17 IC ohv . model # 917.272260 42 inch cut.
Briggs & Stratton 15.5HP Model MFG 7800352 IC engine The above engine powers a Snapper LT 75 Ride-on. It was purchased September 2010 and has done < 50 hours work. There have been unresolved...
if it has a fuel solenoid on the bottom of the carburetor chances are some one has cut the tip off of it causing it to back fire. that is what the fuel solenoid is , a anti backfire fuel shut off. it is nothing to worry about if the back fire don't bother you and it runs good.
Jun 26, 2017 • Garden
Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation
> Blocked VLK
> Windows Product Key: *****-*****-3R89F-D2KXW-VPK3J
> Windows License Type: Volume
> Windows OS version: 5.1.2600.2.00010100.3.0.
Where did you obtain the CD-ROM that you used to install Windows,
using that Product Key?
A "VLK' is a "volume license key" -- when some organization purchases a specific number
of licenses to install Windows XP, Microsoft issues a "volume" license-key,
so that all (up to the number of licenses they purchased) computers in that organization
can use the _same_ license-key.
If Microsoft detects that the product-key is being used *OUTSIDE* of that specific organization,
then Microsoft will *BLOCK* all attempts to "activate" Windows that cite that product-key.
I did a Google-search for '3R89F-D2KXW-VPK3J' and Google reported 37 THOUSAND web-pages that contain that string. That is a *DEFINITE* sign that the VLK has been "leaked" onto the Internet.
So, you are trying to use a "non-genuine" copy of Microsoft Windows XP.
Thus, you are a "SOFTWARE PIRATE".
Purchase a *GENUINE* copy of Windows XP (or Vista or 7) and install it,
and throw away your "pirated" copy of Windows.
10helpful
Craftsman LT 1000 with Briggs and Stratton 20 OHV V-Twin Engine 42 inch cut model number 917271910 What year model tractor do I have?
Need to download manuel for Akari model Number IC-51F88ZA
Hi, try these codes
1157, 1192, 1262, 1298, 2356, 2357.
Regards
Phillip
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
