LG LDF7932ST Builtin Dishwasher Logo
Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does LE mean? My dishwasher is suddenly stopping during a wash cycle a this appears on the little screen
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Jul 01, 2011
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10835156
Points
101584
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Kitchenaid KDPM604KPS dishwasher stops minutes into cycle
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
1helpful
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
1helpful
Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
3helpful
2answers
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
5helpful
Le code on ldf6810bb lg dishwasher
The LE error code can mean that the impeller is damaged or there is some debris blocking the the sump area underneath the filter or the wash motor has failed. In that order.
Remove the spray arm and filter (9 phillips screws) - inspect impeller for damage, with flashlight, look everywhere for debris (watch out for broken glass!) Reassemble and test.
If problems continue, schedule as service call focused on the wash pump/motor.
Good Luck!
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
