Question about U-Line Uline Origins Series Refrigerator/Ice Maker Manual Defrost-COMBO29A
No instructions for installing new seal on door (Uline 75WC Wine cooler
  • Anonymous Mar 20, 2014
    door rubber seal vinothek
  • 3,740 Answers
Service and parts manual is here.
http://stroboflash.com/searayproject/Docs/U%20LINE%20Service%20Manual.pdf
The procedure is as stated in solution 1 by expert Ironfist. The older units had a metal plate with screws that you had to loosed the screws in the retaining plate by peeling the gasket in the opposite direction without tearing it to loosen or tighten the screws on the retaining plate. Then you just lifted the gasket off. When you go to reinstall as previusly stated by the other expert... start in the top center and work to the corners. Make the coners fit before moving down either side to the bottom corners. Again make the lower corners fit and finally install the gasket across the bottom. Once installed rub the gasket mounting area smooth with one finger or thumb.
You have humbled and hornored me with your request. If there is something that your really having difficulty with once you start this gasket change just repsond here and I will get back to you ASAP but, we will complete the task!
Thanks again,
Kelly
Posted on Jun 28, 2011
  • Kelly
    Kelly Jun 28, 2011
    Someday I will spell check! Sorry for not doing so... Kelly
  • 3,018 Answers
  1. First remove the screws from the top hinge with an Allen wrench.
  2. Now tilt the door and lift up to remove the door.
  3. Now remove the door handle.
  4. Now you just pull the door gasket out of the groove it sits in. Nothing fancy to it. Always start at the top middle moving outwards and then down and then back to the middle when you get to the bottom side of the door.
  5. Don't be afraid to yank on it a little bit. Someone holding the door steady will be a real asset.
  6. Now push the new gasket on starting at the corners and moving inward.
  7. Now reverse the steps to get the door back on.
  8. As you are tightening the screws on the top hinge plum/level the door so that it seals right.
  • If you have any questions of comments please feel free to ask.
Regards,Tony
6ya staff
SOURCE:
Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
Jan 22, 2012 | U-Line 75WC Wine Cooler
Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Oct 06, 2009 | U-Line 75WC Wine Cooler
Can you replace a broken glass door in a wine cooler
Only by replacing the door. You can visit www.u-line.com and under customer service you will see parts locator.
Sep 24, 2009 | U-Line 75WC Wine Cooler
I need to replace the door gasket on a U-Line 75WC wine cooler.
Most of the time they send instructions with the new gasket./
Jun 05, 2009 | U-Line 75WC Wine Cooler
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
Unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
Oct 01, 2008 | U-Line 75WC Wine Cooler
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Refrigerators Logo
362 people viewed this question
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
