1. From the Main Menu screen, tap the Settings icon . 2. Tap System. Setting Languages 1. Access the System Settings menu (above). 2. Tap Languages. 3. Tap on the desired language. 4. Tap the back arrow . 5. The Magellan RoadMate receiver will reboot if you change the language. Setting Auto Power Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off automatically. 1. Access the System Settings menu (above). 2. Tap Auto Power. 3. Tap on the desired duration. 4. Tap the back arrow . Setting Brightness 1. Access the System Settings menu (above). 2. Tap Brightness. 3. Tap in the brightness slider to set the brightness of the display. 4. Tap the back arrow . The Dim on Battery Power option will prolong battery life by dimming the display while using internal battery power. Check to turn this option on. Setting the Time Format 1. Access the System Settings menu (above). 2. Tap Time Format. 3. Tap on 24 Hours or 12 hours with am/pm. 4. Tap the back arrow . Selecting the Time Zone (daylight savings on/off) 1. Access the System Settings menu (above). 2. Tap Time Zone. 3. Check Auto Time Zone or select your time zone from one of the cities in the list.
