SOURCE: Instructions for use DiLonghi StiroMeglio compact iron (steam boiler Iron)
Is a long story but i make short.Don`t be afraid to leave your iron on.Is common to water tank iron to get working in more then 5-10 minutes.That machine are really safe since they do have more then 1 thermostat to control the water pressure.
How they work is pretty easy.The boil the water to a certan temperature and you know after certan F. the water become steam generatin pressure and steam.The thermostat control the heater and the electroswitch release the steam
If your in not making any steam after 5-10 minutes make sure you hear the electroswitch working.Sometimes they get cloght and even if the boil is under the pressure you can not get any steam at all
Good Luck
SOURCE: Tefal Pro Express Steam Generator Iron
My Tefal is the same, steams for a while then nothing. I have tried to descale with no joy. I think it may be a problem with an internal thermostat that cuts out stopping the steam.
Any ideas????
SOURCE: steam button on iron has stopped working
this just happened to us & the electronics man at my husband's plant took it apart & said the thermostat needs replaced. the wires were all eaten up so to speak
SOURCE: the boiler part is working fine but i have no
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: Will not send steam to the iron. Cleaned boiler
Assuming the iron is hot???, move the variable steam control from min to max several times to clear possible blockage. Sounds like the steam valve is clogged.
