Some cars require that the onboard computer be cleared of the past error reading. The error reading may cycle out on its' own after 35 or more starts, but some can linger.
If the driveability issues remain, then something else may be at fault. If no driveability issues, then you just need a reset.
Now my information shows a different result for Code 240. There is a problem with a Turbo boost sensor if you have a Turbo on your car.
Hello, as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
Well the "F3" error code means the oven sensor is open an ohmmeter reading for the open circuit should be "?". The part number for the oven sensor is AP2023862. Or the harness to the sensor could be open or shorted. You will need to use a meter to check the sensor circuit wiring harness in order to come up with a final diagnosis. You will need to access the EOC electronic oven control & check the sensor circuit from there for a starting point. The value of the sensor should be 1090ohms
You may purchase the senser from the link below - http://www.appliancepartspros.com/part_details.aspx?part_id=2023862
Check out the below link for digram (most like as your model) -
Hi, yes it is drum RELATED error, but before changeing the drum, clean the drum sensor. When you remove drum unit, inside of copier in drum unit place, from left side, uperr in the middle you have small sensor - Clean it!
Then try again.
If not tell me the exact error code eg. E 020 - 01A2 or?
0001 HP of the ITB fails to be detected even after the specific period of time. Abnormality of the HP sensor, Deviation of the belt from its position to either edge, or soiling of the seal Clean the HP detection seal, Clean/Replace the HP sensor 0002 The next HP fails to be detected within the specific period of time after the HP of the ITB is detected. Clean the ITB back side and the drive roller 0003 The next HP is detected earlier than the specific period of time after the HP of the ITB is detected. The ITB is torn due to scratches, and the sensor detects the tear as a HP by mistake Clean the HP detection seal, Clean/Replace the HP sensor
