I was trying to load some songs on the mp3 but is said that I needed to formate sansa from fat to ntfs after doing that I have the songs I want on the card but when I put the card in the mp3 player it says I have no songs but when I look at the info from the card on a nother reader it says I have over 100 songs
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
The Sansa player will only recognize certain file formats. The songs with a Red X are not eligible to be transferred to your player, because their DRM license does not allow transfer to certain (or any) mp3 players.
It is best to use songs that are in mp3 format only. They will give you fewer headaches.
To format it..on your device..go under..menu, setting and there should be a format option option there.. or you can change the device mode to MSC instead of MTP and right click on the drive which is listed under my computer and click on format..
let me know if that doenst work for you... Hope this helps
P.S.Please rate accordingly... Thank You Computerrep
Reformat the player and try again. You can look at the tips and Tricks in my profile to find out how to format an mp3 player. There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites. WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers. You can also format the player in Windows Media Player itself: Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything. -Tha Mp3 Doctor
