Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
Checking the ink levels on a Macintosh computer
Where is the HP director
. on a mac
where is hp director on mac
first check if you are using refilled ink cartridges!!, most likely the nozzles have worn out and resulting in extra quantity of ink being released which in turn makes the print blurry. Best replace the cartridges with new ones from HP(original), after which you may refill when it finishes.
mine canon e484. automatic scan copy print. colored instead how black print copy scan? 3 months even couldnt was, how cartridge finished. however cartridge's finishing whether im not sure, but generally device of screen on ''running ink level low'' that telling.
SOURCE: ink level problem
Print a test page to determine if the color cartridge is working
Verify the correct printer is selected as the default printer
Check that the printer settings are correct
SOURCE: check ink cartridge levels
If using Windows, you could go to Control Panel -> Printers and Faxes -> select printer and right click. At the context menu, select 'Properties'. There may be a tab there to view the ink levels.
Also, the manufacturer of the printer may have software you could install from their website.
SOURCE: How to check ink levels on deskjet 5150?
Download the instruction Manual for the HP deskjet, model 5150:
http://h10025.www1.hp.com/ewfrf/wc/product?product=304431&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7〈=en&cc=us
SOURCE: printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
SOURCE: Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
