There are some adjustments that you can do if you carefully follow the instructions in the video below. I also have a Whirlpool Ice Maker Troubleshooting and Service Manual upon request. Your 67003753 Water Inlet Valve=> 67003753 Water Inlet Valve could be leaking and creating this block of ice. For most Whirlpool/Maytag brand ice makers is is cheaper to replace the core module part number=> D7824706Q Ice Maker Module. Reason being the individual parts add up to more than the cost of all those parts together. Now if interested you can request a Whirlpool Ice Troubleshooting Service Manual by filling out the capsha=> HERE Reason I don't place the manual's here because Whirlpool ask me not to do so, but I will be glad to send you one. The manual is the solution but the most complete module or replacing water valve is the cheapest route. Below is how it is explained a little simpler. If I can help you in any way please ask, Thanks, Sea Breeze
If helpful please rate this solution.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
