SOURCE: JVC AV-56WP74 Problem
Yes, one of your convergence IC's have gone bad. They are located on the convergence board inside the tv and there are two of them. They are inexpensive and easy to replace if you know how to solder. Watch out for the JVC booby trap sensor on the dvi input card. Don't run the tv with the back panel off unless you have disconnected the DVI card from the main board. I would even cover the little sensor with black electrical tape. Then it is safe to work on the tv when it's open and on. Well safe for those who know what they are doing.
SOURCE: samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
SOURCE: Have a 46f500 hitachi projection television.
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
SD TECH
